Radioman56
Sep 22, 2021Follower
Nighthawk® Tri-Band WiFi 6E Router Died?
Hi My Nighthawk Router Model AXE 11000 seems to have just died. The signal coming into the Nighthawk from my Netgear Modem still passes-through the Nighthawk and connects from the Nighthawk through t...
Sep 23, 2021Guru - Experienced User
1. what modem do youi have? (wondering if you're getting modem/router mixed around in your description)
2. What firmware is on the router?
3. does wired devices work on the router?
4. Did the wifi on/off button get hit? Push and hold it for 2 seconds.
