tpm1952
Sep 29, 2021Aspirant
Nighthawk 1750 Internet LED is AMBER - ?
I have recently been experiencing my internet connection going up and down. This router is connected to an Arris cable modem. The ISP says themodem is woring properly. But the internet LED on the rou...
- Sep 29, 2021
If its failing when connected directly to the modem, its seeming to indicate a line/modem issue?
Since the router isn't connected.
tpm1952
It happens about every 25 min or so.
The light goes from white to amber. Then typically the internet connection is lost.
When failing I tried connecting a device directly to the Arris ethernet port to test and it also failed (would not connect).
Then I typically power down both devices to get it to eventually come back up but it does not always come back. And if it does the light is usually amber on the router.
Sep 29, 2021Guru - Experienced User
