JohnnyWB's avatar
Nov 18, 2015
NightHawk 1750 WIFI Router has locked me out of my own network?
I log onto my computer, well I attempted to log onto my computer this morning and access the web and it tells me that I have been blocked for some strange reason.  When I pull up the Genie, it shows ...
  • Retired_Member's avatar
    Retired_Member
    Nov 18, 2015
    I would Delete Genie and preforum a factory reset press reset until Power led flashes. Use default settings found on router label.
    Your post to me is confusing and starting over from scratch would be my advise.
    Good Luck!
