Dana2317's avatar
Dana2317
Follower
Oct 27, 2022
Nighthawk 2.4 isn’t showing up but looks to be working on nighthawk. Any ideas how to fix it?
  • FURRYe38's avatar
    Is there a NG router model# that your referring too?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • plemans's avatar
    What router do you have?
    You say its not working but looks to be working on the nighthawk? Do you mean its showing enabled on the online browser?
    What firmware version are you on?
    Does it have smart connect? (smart connect combines the 2x ssids if you have a dual/triple band device)
