Thebennys4
Apr 23, 2021Follower
Nighthawk 5Ghz Useless (Netgear PAY ATTENTION!)
I see it over and over in here and somehow the discussions are marked "solved". No, theyre not solved. When the only solution is to reset a router to 3 or 4 year old firmware, that should not be accep...
shadowsports
Apr 24, 2021Hero
Thebennys4 wrote:
I see it over and over in here and somehow the discussions are marked "solved". No, theyre not solved. When the only solution is to reset a router to 3 or 4 year old firmware, that should not be acceptable on any level. Shame on you Netgear! How about we get a Netgear nerd on here to tell us what's really going on with the 5Ghz being absolutely useless on these routers? Anyone?
I have a couple dual and tri-band Netgear routers and the 5G works great. I am not using 3 ~ 4 yr old FW.
If you are looking for help, post your question (problem or issue) and provide specific information about your environment, including any troubleshooting steps you have performed. We can try to assist.
