Thebennys4
Apr 23, 2021Follower
Nighthawk 5Ghz Useless (Netgear PAY ATTENTION!)
I see it over and over in here and somehow the discussions are marked "solved". No, theyre not solved. When the only solution is to reset a router to 3 or 4 year old firmware, that should not be accep...
nickp221
May 07, 2021Apprentice
Here's another "theory" you'll see a lot on here: NetGear firmware is hot garbage.
Don't count on any NetGear firmware update to solve any problems you are having; it will likely make it worse.
I had the same experience with my X10, the 5Ghz was not great but after switching to DD-WRT and applying the optimum configuration for wifi settings I found on their forums, it was like a whole new world. All wifi bands are faster and more reliable than ever, so good I almost forgot I spent $400 on a router that I had to pay shipping to RMA once then the replacement failed again a year later and now can't run stock firmware at all.
