kevinbcrocker
May 28, 2020Tutor
NightHawk 6700 v1 not providing 1Gb internally
I'm not getting the 1Gbps speeds that the docs say I should be getting. I've connected directlly to my Cable Modem (Armstrong Arris) andspeed test shows the 500 Mbps speed I'm paying for, BUT as ...
- May 29, 2020
kevinbcrocker wrote:I'm not getting the 1Gbps speeds that the docs say I should be getting.
I've connected directlly to my Cable Modem (Armstrong Arris) andspeed test shows the 500 Mbps speed I'm paying for, BUT as soon as I connect the same cable between the cable modem and the R6700 router the speed drops to 200 Mbps.
Surely there is some setting that enables the proper speed. Would a factory reset help?
I've read through lots of documentation and found nothing that helps,s o I'm here asking all you experts for your help.
Thanks in advance.
Kevin
Which arris modem is it?
What firmware is on the R6700?
A factory reset is never a bad idea. Reason why is some settings (qos, traffic monitoring, access control) require traffic monitoring and aren't recommended at speeds >250mbps. And I've read of the settings being retained even though disabled and the device rebooted.
So try factory resetting and then during setup, make sure to leave qos, traffic monitoring, access control disabled. you can also try enabling ipv6.
May 29, 2020Guru - Experienced User
Thanks in advance.
Kevin
kevinbcrocker
May 30, 2020Tutor
Arris modem:
CM3200A
R6700 firmware:
Firmware Version
V1.0.2.8_10.0.53
- plemansMay 30, 2020Guru - Experienced User
did you try the reset?
