Thomfoolish
Jan 04, 2022Follower
Nighthawk 6700 v3 amber blinking power after failed firmware update
I tried to update my router via the Netgear Nighthawk app and it failed in the process. Now, it is unable to connect to the internet and only displays a blinking orange power light. I tried to power c...
Jan 05, 2022Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
