Gene0912
Mar 17, 2021Aspirant
Nighthawk 6900 Internet light not on
Mar 17, 2021Guru - Experienced User
You didn't really give us much to go off.
What modem do you have?
What firmware is on the router?
Is this a new purchase? Did it work before? What changed?
What have you done to try to fix the problem?
we aren't there to see what your setup is or whats going on so you need to help us to help you with details and specifics.
thanks.
There's also a r6900, R6900p, C6900 (combo device). Seeing as how you only put 6900, tough to say which you have or whats going on. Again, details.
https://www.netgear.com/support/product/R6900
https://www.netgear.com/support/product/R6900p
https://www.netgear.com/support/product/c6900
- Gene0912Mar 17, 2021AspirantSorry! Modem with Cox. I’ve had it for a little over a year now. It was working well before and the firmware is at V1.0.2.8_10.0.38. I e tried rebooting both modem 1st waited around 10mins then turned on the Router. Recycling it I guess that was what it was called. Changing Ethernet cord. But all these to no avail.
