Les_House
Jun 13, 2017Aspirant
Nighthawk 7500V2 Firmware Version 1.0.3.10 Corupted File
I have tried to download firmware Version several times on different computers. Each time I try to unzip the file I get a message that the file is cotupted.
- Jun 16, 2017
I discovered my problem. Operator error. I did not realize that you could not extract the Zip files just by right clicking on the file in windows 10. I was able to unzip the file when I used the proper Windows 10 procedure.
JamesGL
Jun 15, 2017NETGEAR Employee Retired
Hi Les_House,
I was able to download the file without any issue. Make sure the download is completed and check the file size. In my case the file size is 22MB.
- Les_HouseJun 16, 2017Aspirant
Each time I dowloaded the file the download was complete. Only took a few seconds to download. I have used Firefox, Chrome, and Opera browsers on ttwo separate Windows 10 computers. With the same result.What was yout operating system when you did the upgrade?
- JamesGLJun 18, 2017NETGEAR Employee Retired
Hi Les_House,
Were you able to update the firmware of the router?
