Les_House
Jun 13, 2017Aspirant
Nighthawk 7500V2 Firmware Version 1.0.3.10 Corupted File
I have tried to download firmware Version several times on different computers. Each time I try to unzip the file I get a message that the file is cotupted.
- Jun 16, 2017
I discovered my problem. Operator error. I did not realize that you could not extract the Zip files just by right clicking on the file in windows 10. I was able to unzip the file when I used the proper Windows 10 procedure.
JamesGL
Jun 15, 2017NETGEAR Employee Retired
Hi Les_House,
I was able to download the file without any issue. Make sure the download is completed and check the file size. In my case the file size is 22MB.
JamesGL
Jun 18, 2017NETGEAR Employee Retired
Hi Les_House,
Were you able to update the firmware of the router?
