Yugpot
Jul 08, 2023Aspirant
Nighthawk 7800
Around the clock tonight I lost Internet to the house. I have talk to spectrum Internet and they’re sending somebody out Wednesday to see if it might be in the line. But I’ll have all my router is the...
- Jul 09, 2023
First you will have to say a bit more than "it doesn't work".
What do the LEDs on the front of the C7800 look like?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the section in the manual Troubleshoot With the LEDs.
Kitsap
Jul 08, 2023Master
Yugpot wrote:
Around the clock tonight I lost Internet to the house. I have talk to spectrum Internet and they’re sending somebody out Wednesday to see if it might be in the line. But I’ll have all my router is the red light that indicates it’s getting power I don’t know how to get inside or like to come on. Do I need to reset the router as in push a button. I’ve unplugged it and left it for two minutes and Spectrum has ran stuff on their end and I saw when I lost power that’s at 5 o’clock..
Initial indications for your router are not good. What happened when you lost internet? A storm, power outage, some other event?
What is the brand name and model number of the modem that is connected upstream of your router? You may have to look on a label.
Yugpot
I have a nighthawk 7800. That has the router and modem in one unit. The only light on is the power light. All the other lights are blank.
- KitsapJul 08, 2023Master
Yugpot wrote:
I have a nighthawk 7800. That has the router and modem in one unit. The only light on is the power light. All the other lights are blank.OK, so it is a C7800. That closes off some of your options.
- YugpotJul 08, 2023AspirantNothing that I know of . it just quit working, but there could be an issue at the feed from the Powell into the house... Charter is sending somebody out Wednesday to check to make sure I’m getting a signal into the house.
- michaelkenwardJul 09, 2023Guru - Experienced User
Yugpot wrote:
I have a nighthawk 7800. That has the router and modem in one unit.Best discussed here:
Cable Modems & Gateways - NETGEAR Communities
