Yugpot
Jul 08, 2023Aspirant
Nighthawk 7800
Around the clock tonight I lost Internet to the house. I have talk to spectrum Internet and they’re sending somebody out Wednesday to see if it might be in the line. But I’ll have all my router is the...
- Jul 09, 2023
First you will have to say a bit more than "it doesn't work".
What do the LEDs on the front of the C7800 look like?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the section in the manual Troubleshoot With the LEDs.
Yugpot
I have a nighthawk 7800. That has the router and modem in one unit. The only light on is the power light. All the other lights are blank.
Kitsap
Jul 08, 2023Master
OK, so it is a C7800. That closes off some of your options.
What happened when you lost internet? A storm, power outage, some other event?
- YugpotJul 08, 2023AspirantNothing that I know of . it just quit working, but there could be an issue at the feed from the Powell into the house... Charter is sending somebody out Wednesday to check to make sure I’m getting a signal into the house.
