Yugpot
Jul 08, 2023Aspirant
Nighthawk 7800
Around the clock tonight I lost Internet to the house. I have talk to spectrum Internet and they’re sending somebody out Wednesday to see if it might be in the line. But I’ll have all my router is the...
- Jul 09, 2023
First you will have to say a bit more than "it doesn't work".
What do the LEDs on the front of the C7800 look like?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the section in the manual Troubleshoot With the LEDs.
Yugpot
Jul 09, 2023Aspirant
Can you be more Pacific and tell me which one of these is the best thing to try first and then second and then third and then if not those work I’ll go buy a new one. Everything like I don’t know what I’m talking about but I don’t so how should I proceed as far as first second and third only one
- michaelkenwardJul 09, 2023Guru - Experienced User
Support | NETGEAR
