Huminie
Apr 23, 2018Tutor
Nighthawk 7900 Drops Internet Every 48 Hours
Having what I think is a weird issue. Every 48 hours (I could almost set my watch to it) my Nighthawk 7900 router loses it's interent connection. If I log into the web interface it says everything ...
- May 10, 2018
Just to close this out. I switched to the R7800 nearly 2 weeks ago, and it has been rock solid. The issue of the internet connection dropping every 48 hours has stopped.
It would appear that there is some sort of issue with the Costco R7900 firmware. It doesn't seem to affect everyone, but there are others out there with the same issue. Hopefully they will get it fixed, but for now, the 7800 seems very capable an no noticible difference other than not having the network go down every two days like clockwork.
Thanks for those who offered advice and suggestions!
Huminie
Apr 23, 2018Tutor
Thank you...very good information.
The lease shows 14 days, and it renewed on my reboot of the router, but you might be on to something there.
My modem is built into my DVR from my cable company. Here are the details:
ARRIS DOCSIS 3.0 / SIP 2.0 Touchstone Media Gateway
HW_REV: 9
VENDOR: Arris Interactive, L.L.C.
BOOTR: 2.3.1.1
SW_REV: 7.14.75.SIP
MODEL: MG5225G
The event log does show one entry for today:
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=ac:b3:13:ce:87:c1;CMTS-MAC=00:01:5c:a2:b2:59;CM-QOS=1.1;CM-VER=3
I will need to research what those MAC addresses belong to. I don't think they are my router though.
But thanks for the help. I will do some more observing based on this and see if I can figure it out.
But still open to other suggestions if someone has another idea.
Thanks!
IrvSp
Apr 23, 2018Master
ac:b3:13:ce:87:c1 is owned by Arris... The other is Cadant, probably on the cable modem termination system of your ISP.
It is 'possible' the modem went to RENEW the WAN IP Address and it never get a response back so it dropped the connection.
14 days is quite long... many are either 24 or 36 hours. My ISP, Charter uses 36 hours. It is quite normal at the 1/2 time point for the device to ask for a IP RENEW. If it can't get one it will try again at some pre-determined point.
I really think, and expecially since this is the 2nd router with the problem, the problem resides with your ISP, either the backend of the ISP or something with your lines.
