Chops42
Oct 18, 2021Initiate
Nighthawk 7900P FW v1.4.2.84, getting web site not found DNS_PROBE_FINISHED_NXDOMAIN errors
After upgrading my Nighthawk 7900P to firmware v1.4.2.84, I am getting a fair amount of web site not found DNS_PROBE_FINISHED_NXDOMAIN errors and have to reload to get to the web site. I had to d...
Oct 18, 2021Guru - Experienced User
You're not the first to report the issues. Its across mutliple product lines.
One thing you can try is enabling ipv6 on the router if you update it. I've see some issues with that disabled on the newer firmwares
- michaelkenwardOct 19, 2021Guru - Experienced User
You can say that again:
Search - NETGEAR Communities - DNS_PROBE_FINISHED_NXDOMAIN
