sanjay92
Dec 23, 2021Aspirant
Nighthawk 7969p redirect traffic from one IP to another IP
Hi, Is it possible to do Network Address Translation from one IP to another IP as shown by iptables command in attachment From IP 209.83.244.20 to 8.8.8.8 Wifi router Nighthawk 7960p
Dec 23, 2021Guru - Experienced User
Probably need to enable telnet under 192.168.1.1/debug.htm
I'd confirm with users in the reddit thread about using that on NG routers.
Is the R7960P the host router or is OOMA host router?
sanjay92
I am using 7960p connected to cable modem Xfinity and one of LAN port in WiFi router connected to OOMA.
So I am not using ooma as a router.
- sanjay92Dec 23, 2021AspirantSo one of IP which is owned by Ooma is not working so folks on reddit found workaround to redirect traffic from Ooma IP to Google DNS. This is what I want to do.
- sanjay92Dec 23, 2021Aspiranthttps://kb.netgear.com/24322/How-do-I-set-or-edit-static-routes-on-a-NETGEAR-router
This looks good except it says that Gateway IP should be LAN segments so I am not sure whether this work - FURRYe38Dec 23, 2021Guru - Experienced User
IF you have the 7960P as the main host router, the easiest configuration for the OOMA is to use the DMZ on the 7960P. This will ellieviate VoIP issues. I've used this before for VoIP devices.
- sanjay92Dec 23, 2021AspirantWell, that is not issue. Issue is on Ooma end. Can you tell whether NAT translation as I have asked earlier, is possible in Netgear or not. If it is not possible then I will look in some ddwrt router.
https://www.reddit.com/r/ooma/comments/rfpmfn/ooma_hub_flashing_red_light_after_power_outage/?utm_medium=android_app&utm_source=share
