PhilFromCA's avatar
Sep 16, 2022
Nighthawk 8000 can't change device name in Advanced > LAN Setup
I'm trying to change the device name on two printers from their HP device names to names like "Laser" and "Inkjet."  However, when I select a device from the list and click on the EDIT button, and then change the device name, the change doesn't take effect.  I have clicked on the REFRESH button after doing the edit, which does show the change.
What can I do?
  • FURRYe38's avatar
    What browser are you using? Try a different browser?
    Is there any spaces or special characters in the name?
    Did you select the Apply button after making the edit change?
    • PhilFromCA's avatar
      PhilFromCA
      Tutor
      I'm using the latest available firmware, V1.0.4.84_10.1.84   (This is a copy-and-paste from the browser page.)  I should mention that I do admin work on the browser on an as-needed basis.  Which means in this case, I may not have done any admin work since I upgraded to this firmware.
      My system is Win 10 Pro 64, updated to 2021H2 plus most recent MS patches.  My browser is Firefox 64 104.0.2 (64-bit) (copy and paste from Firefox help page.)
      I did click on the APPLY button after making the change. I just repeated my earlier steps.  Here is a screenshot of the main LAN setup page after applying the change.
      • FURRYe38's avatar
        Is it only this one device that you can't change the name?
