Reggietaylor
Apr 20, 2022Guide
Nighthawk A1900 R6900v2 loosing connection with devices
Currently running a Nighthawk AC1900 R6900v2 Router with Firmware Version V1.2.0.62_1.0.1 I have recently started having issues with connected devices loosing connection to the router. The list ...
Apr 20, 2022Guru - Experienced User
Are the devices with issues connected to the 2.4ghz or the 5ghz?
What firmware is on the router?
What modem/gateway is the router connected to?
When its having issues, what actual error do you get? Does it connect but say "connected, no internet". Does it disconnect from the wifi entirely? What actually happens?
