Reggietaylor
Apr 20, 2022Guide
Nighthawk A1900 R6900v2 loosing connection with devices
Currently running a Nighthawk AC1900 R6900v2 Router with Firmware Version V1.2.0.62_1.0.1 I have recently started having issues with connected devices loosing connection to the router. The list ...
Reggietaylor
Apr 20, 2022Guide
Currently running on 2.4ghz. Some of the smart plugs and smart bulbs will not work if 5ghz is turned on. I had to turn 5ghz off and leave it off to get them set up and keep them working.
Router Firmware Version V1.2.0.62_1.0.1
Arris TM1602 Cable modem from Spectrum
Here's a summery of what I see happen.
It's mostly with iPhones, laptop, and Firesticks. It also occasionally happens to our Honeywell thermostat too.
We still have the Wifi connection icon on the screen on our iphones but can't connect to any websites through the browser. In our area, we have no cell service and use Wifi calling and internet.
Firesticks simply says "no internet connetion" when trying to connect to directly to the router but will connect fine with the range extender, which is a cheap ZettaGuard I got free from Amazon for a review.
My laptop simply shows a grayed out Wifi indicator with an exclamation mark in it. My laptop does not like the extender. It will connect but the connection is extremely slow.
When I reboot the router, everything returns to normal. All devices will connect to the router instead of the extender.
Thanks for taking your time to trying to help me. I am very uneducated when it comes to routers.
Apr 20, 2022Guru - Experienced User
2.4ghz is a very slow network and sensitive to interference.
If you're devices have 5ghz, that's what they should be connecting to as its significantly faster and suffers from much less interference.
Your smart devices shouldn't care if they don't have 5ghz whether its on or not.
And if they do have 5ghz, they're higher end IoT devices and should connect fine.
I'd try turning 5ghz back on and select a channel in thee 149-165 range for its channels.
For your 2.4ghz, try manually selecting a channel on either 1-6-11
- plemansApr 20, 2022Guru - Experienced User
also, something to keep in mind is Netgears consumer routers are limited to 32 devices per band. If you're having 35, whenever a new device connects, it kicks an old device or different device off. Its why you have the 2 bands so you can put some on each band. Plus with 2.4ghz being slow, its better to just put the IoT devices on it.
So enable your 5ghz and just disable smart connect on the router. then you can setup the 2 bands separate. that might help the stability a bit.
- ReggietaylorApr 20, 2022Guide
Now that I think about it, I never recall having any problems until I installed the smart dimmer switch on our ceiling fan and the three new smart bulbs in the guest bedroom. The smart dimmer was for me. Just so I don't have to get out of my recliner to slow the fan. The smart bulbs were for the grandkids in our guest bedroom. I like to surprise them sometimes with something new.
I really appreciate your time and valuable knowledge. I will give your suggestions a shot later today or tomorrow. I am a 12 hour rotating night shift worker. I just got off two consecutive nights from hell. Gonna nap a while then give this a try.
Thanks once again. I will let you know how it goes.
I hear you. I was on nights for 7 years on the 12 hours shift. Never feels like you're at 100%
