Brendo13
Nov 19, 2020Follower
Nighthawk AC 1750 6400v2 Light Blinking Amber and won't show networks
Hi, Recently my nighthawk ac1750 6400v2 will not show my wifi networks and the power button will only blink amber. Factory reset does not work, I've tried using third party software to re-ins...
antinode
Nov 19, 2020Guru
> [...] the power button will only blink amber. [...]
> [...] tried tftp protocols to install firmware. [...]
The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error. By itself,
saying that you "tried" it doesn't say much. As usual, showing actual
actions (commands) with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations. Especially when using a command-line program,
copy+paste is your friend.
