kaschmidt
Feb 17, 2022Follower
Nighthawk AC 1900 not connecting to wifi
We have Nighthawk AC1900 Smart WIfI Router, Model R7000. Our TV in shop behind our house works fine router. The TV in our bedroom will not connect to wifi. It says password invalid. We have not chan...
Feb 17, 2022Guru - Experienced User
What security wifi configuration do you have set on the R7000 web page?
WPA2 and AES should be used.
Try a factory reset and setup from scratch.
Press the reset button for 10 seconds then release. Walk thru the setup wizard with a wire connected PC and web browser.
