mlg250
Feb 26, 2016Aspirant
Nighthawk AC 5300 reboots to factory settings when I plug in my Ooma Telo
My AC 5300 has been working very well with wide coverage for all of the three months I've had it. However, I seem unable to plug my Ooma Telo into the router without having the router reboot and oft...
- Feb 29, 2016
What do you mean when you say to reset the router via "gui"? I have had to use the reset button twice to get my signal back after Time Warner was on the block doing work. But it reset right away, found my network etc. and I was up and running.
Thanks
mondenath
Feb 27, 2016Prodigy
Take backup and reset the router via gui. See without adding any additonal rules just keeping the wifi network safe with security and login changed if the router is stable. Then slowly add if any forwarding/triggering or QOS based rules along with additional settings etc. See if any new setting keeps triggering the router to reboot.
- mlg250Feb 29, 2016Aspirant
Thanks
