mlg250
Feb 26, 2016Aspirant
Nighthawk AC 5300 reboots to factory settings when I plug in my Ooma Telo
My AC 5300 has been working very well with wide coverage for all of the three months I've had it. However, I seem unable to plug my Ooma Telo into the router without having the router reboot and oft...
- Feb 29, 2016
What do you mean when you say to reset the router via "gui"? I have had to use the reset button twice to get my signal back after Time Warner was on the block doing work. But it reset right away, found my network etc. and I was up and running.
Thanks
Anonymous
Feb 27, 2016How was it connected before. Was it between modem and router or was it after the router?
Find your Ooma manual Read It, Study it. Depending on how it's placed in the network you'll have to change some settings. Specifically DHCP.
mlg250
Feb 29, 2016Aspirant
It was plugged in after the router, which (before the Nighthawk), was an Apple Extreme. Never had any trouble.
When you say "change settings in the network", do you mean on my computer in networking? Running Win 7 Prof 64 bit with lots of memory and disk space.
Thanks again
