mlg250's avatar
mlg250
Nighthawk AC 5300 reboots to factory settings when I plug in my Ooma Telo
My AC 5300 has been working very well with wide coverage for all of the three months I've had it.  However, I seem unable to plug my Ooma Telo into the router without having the router reboot and oft...
  • mlg250's avatar
    mlg250
    Feb 29, 2016
    What do you mean when you say to reset the router via "gui"?  I have had to use the reset button twice to get my signal back after Time Warner was on the block doing work.  But it reset right away, found my network etc. and I was up and running.
    Thanks
