bryanchance
Aug 17, 2021Aspirant
Nighthawk AC1200
The setup process is the dumbest thing I've ever seen on anyting. I can't complete the setup unless I create an account with netgear. I need to have a working internet connection to SETUP the route...
michaelkenward
Aug 18, 2021Guru - Experienced User
Seems like you are doing something wrong. There is no need for any account if you are trying to set up a router. (I assume that was what you mean by Nighthawk AC1200.)
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device. AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Begin with the Quick Start/Installation Guide. And be careful, to do things in the order laid down there.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
