camerondaw
Jan 17, 2022Aspirant
NIghthawk AC1750 and Nighthawk AX5400 keep dropping wifi - tried everything!
Sorry long story, but I hope to get some answers because I have tried everything. Southcentral Texas person here, my ISP is Sparklight, and for the first year, everything was great. The issues starte...
camerondaw
We bought our own modem which is also Netgear. I am attaching a screenshot of the log to this post. From my limited understanding I don't see any thing from the log that gives me clues to what is happening.
So far it has been all wireless devices, I haven't had anything wired into the router when this happens.
Jan 17, 2022Guru - Experienced User
the event logs from the modem and the cable connections page. it shows the upstream/downstream info
- camerondawJan 17, 2022Aspirant
Got it -
All above are event logs, this last is the cable connections info
- plemansJan 17, 2022Guru - Experienced User
your power levels are out of spec. You should be between -7.5dbmv and 7.5 dbmv. You're at -15.3 to -12.8dbmv.
Check your link for splitters, amplifiers, signal attenuators and remove them if you do.
If you can, direct connect the modem to right where the line comes into the home to prevent wiring in the home being an issue.
