nguser1750
Feb 13, 2022Tutor
nighthawk ac1750 DHCP-DNS setup
I am trying to get pi-hole with unbound working on my network. My sysadmin/network guru friend is telling me: "The DHCP configuration in the router (that is the DHCP server configuration that pas...
Feb 14, 2022Guru - Experienced User
You're using the router as the dhcp and the pi-hole as dns?
Or are you trying to setup the pi-hole to run as DHCP and dns?
Usually what I do, is setup the pihole's ip address into the routers primary dns for both the ipv4 and ipv6 setup.
then you have to make sure in the pi-hole, you have the dns servers selected for what you want used after the blocking.
I did a quick screen snip/paste into word of my ipv4/6 settings and my pihole dns setting
