nguser1750
Feb 13, 2022Tutor
nighthawk ac1750 DHCP-DNS setup
I am trying to get pi-hole with unbound working on my network. My sysadmin/network guru friend is telling me: "The DHCP configuration in the router (that is the DHCP server configuration that pas...
michaelkenward
Feb 14, 2022Guru - Experienced User
nguser1750 wrote:
If so, I have been unable to find out how/where this is done in the router configuration. Hoping someone here can point me to how/where this is done via the router's configuration software as my friend is not familiar with this particular router.
I'd expect what works on one router to work on another one. You just need to get to the settings that your fiends has tweaked. Either that or the well developed pi-hole community.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
nguser1750
Feb 14, 2022Tutor
The manual was of no help. Web searches yield forums which state Netgear does not support this. Other users have resorted to loading alternative router firmware on their Netgear Hardware. I am not willing to go there...
Thanks.
