nguser1750
Feb 13, 2022Tutor
nighthawk ac1750 DHCP-DNS setup
I am trying to get pi-hole with unbound working on my network. My sysadmin/network guru friend is telling me: "The DHCP configuration in the router (that is the DHCP server configuration that pas...
nguser1750
Feb 14, 2022Tutor
Yes. Currently using router for DHCP and pi-hole for DNS. My understanding now is, that with Netgear's limitations, I will have to use the pi-hole for both.
I don't see your Word document with the snip/paste of your setup. (?) How do I get to it?
Greatly appreciate the help.
Feb 14, 2022Guru - Experienced User
It was actually a pdf. Had to redo it because the forum wouldn't take a word docx. You can setup pihole dns on this. I've done it on multiple routers from Netgear
- nguser1750Feb 14, 2022Tutor
Got it! Thanks for your help!
- plemansFeb 14, 2022Guru - Experienced User
Hope you're able to get it running. If not, let me know where its failing (screen snips help) because I've messed around with it a bit.
And pihole works great with some fine tuning of the lists.
