Murby
Jan 21, 2020Aspirant
Nighthawk AC1750 R6400
My Nighthawk Router is plugged into my ISP's modem/firewall/router. When the Netgear Nighthawk loses power or has to be rebooted, the time setting gets screwed up and it can't get the new time ...
- Jan 21, 2020
RFC 5905 governs NTP (time server), which means you must always use UDP port 123. Try that... I don't see why Netgear would use a non-standard port.
Murby
In simpler terms, to be more clear:
My ISP's firewall/modem is blocking whatever time server the Netgear router uses. If I drop the ISP's firewall, the time on the netgear router works fine.
What ports do I forward/trigger on my ISP's firewall, or what do I need to do in order to allow the Netgear router to update its time automatically?
Thank you
booboo59
Jan 21, 2020Apprentice
- MurbyJan 21, 2020Aspirant
I went into the ISP's modem/router, set it to trigger on UDP port 123 and it works.. well... at least it works on my computer now. My PC wouldn't update its time unless I dropped the firewall, now it updates with the firewall up.. Going to assume the Netgear router will do the same.
Thank you,
