LLEONG
Oct 05, 2015Tutor
Nighthawk AC1750 R6700 failure to authenticate for configuration backup
I am getting an authenticate error when trying to backup the configuration on a new Nighthawk AC1750 Model R6700 router. It has the latest firmware, V1.0.0.2_1.0.1. A authentication challenge appea...
- Oct 05, 2015
Wish I could just close this post. Found my error. After multiple failures trying to authenticate (with the wrong password), the Netware Genie will eventually take you to a password reset screen. Go through the routine and it will reveal to you the correct password. In my case, it was actually blank because of some attempts I had made earlier to change the admin password...but that's another story.
