LLEONG's avatar
LLEONG
Tutor
Oct 05, 2015
Nighthawk AC1750 R6700 failure to authenticate for configuration backup
I am getting an authenticate error when trying to backup the configuration on a new Nighthawk AC1750 Model R6700 router.  It has the latest firmware, V1.0.0.2_1.0.1.  A authentication challenge appea...
  • LLEONG's avatar
    Oct 05, 2015
    Wish I could just close this post.  Found my error.  After multiple failures trying to authenticate (with the wrong password), the Netware Genie will eventually take you to a password reset screen.  Go through the routine and it will reveal to you the correct password.  In my case, it was actually blank because of some attempts I had made earlier to change the admin password...but that's another story.
