Running-Bear
Jan 10, 2022Aspirant
Nighthawk AC1750 router Model # R6700 - Can't sign on the Nighthawk app on my iphone
I was using the Nighthawk app on my iphone until the other day when I accidently blocked my pc in the app and signed off the app and the PC. The next day I tried to bring up my PC and it wouldn't co...
- Jan 10, 2022What Firmware version is currently loaded?What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update?
Jan 10, 2022Guru - Experienced User
Running-Bear
Jan 19, 2022Aspirant
Hi FURRYe38,
I ended up changing out the router as I had given out the Serial number to the router I was having problems with and thought that information might allow the other party to get my password even though I had set up the two questions? Otherwise, I think that your suggestion of resetting the router to the factory settings would have worked. Thank you!
- FURRYe38Jan 19, 2022Guru - Experienced User
Good Luck.
