Jstrick33
Nov 09, 2023Aspirant
Nighthawk AC1750 Router (R6700v3) will not power on.
When I plug in the router and press the power button on the back, the Power light, and the 2.4Ghz, 5Ghz, Guest Wifi, and USB 3.0 lights all blink one time and then nothing happens. I tried the reset...
- Nov 09, 2023
I think you're right. I didn't realize it, but the cord is the wrong cord. It goes to a motorola... I will try locating the correct power supply cord and try it again. Thanks.
michaelkenward
Nov 09, 2023Guru - Experienced User
Do you mean that all the lights go off and you have a dead device?
If the power LED comes on and stays on, what colour is it?
Do you have a separate power supply that you could try? One with the same volts and amps as the one you use now?
