Jstrick33
Nov 09, 2023Aspirant
Nighthawk AC1750 Router (R6700v3) will not power on.
When I plug in the router and press the power button on the back, the Power light, and the 2.4Ghz, 5Ghz, Guest Wifi, and USB 3.0 lights all blink one time and then nothing happens. I tried the reset...
- Nov 09, 2023
I think you're right. I didn't realize it, but the cord is the wrong cord. It goes to a motorola... I will try locating the correct power supply cord and try it again. Thanks.
michaelkenward
Nov 09, 2023Guru - Experienced User
Jstrick33 wrote:
I have tried several different outlets. I do not think it is an outlet problem.
I was not referring to "outlets". I suggest trying a different power supply, the transformer (adapter) that plugs into the mains outlet and the router.
Jstrick33
- michaelkenwardNov 10, 2023Guru - Experienced User
Another one with too many old power bricks lying around. It is a modern disease.
Let's hope the Motorola adapter didn't do any lasting damage to the router.
Look on the R6700 for its power consumption, then track down a replacement with the same output. (More amps is fine.)
- Jstrick33Nov 10, 2023Aspirant
Found the right one and seems to be working just fine. Thanks for the help.
