slanwar01
Feb 08, 2021Follower
Nighthawk ac1750 won’t connect to internet
Just installed arris T25 which works fine connected to my computer but netgear will not connect to the internet when plug the same cable that was connected to my computer, tired of unplugging the mode...
Feb 09, 2021Guru - Experienced User
You're using the T25 as the modem?
And you have the C6300 for a router?
Or what actual router do you have?
(hint, ac1750 is a speed)
