bowlero2
Jan 25, 2021Aspirant
Nighthawk AC1750
Have owned for about a year. Most status lights are currently blue. recently purchased a cat 6 ethernet cable to attach to laptop and the status light is RED. Why the diffence between blue and red st...
- Jan 26, 2021
That router doesn't have any red led's built into the ethernet leds. . Its only amber/white.
check in your network settings to see if its connected at a 100mbps link rate. If so, its amber (but maybe looks red).
Jan 25, 2021Guru - Experienced User
which status light?
the manual tells you which each led is and indicates.
you can find the manual here: https://www.netgear.com/support/product/r6700
- bowlero2Jan 25, 2021Aspirant
was asked as a reply "which status light". The status lights corresponding to ethernet port 2, 3, 4, (tried all three) all light up red whenever I plug in my laptop It was even suggested that I download the manual and it would explain it to me. Nothing in there about red lights that I have found.
- plemansJan 25, 2021Guru - Experienced User
Don't suppose that color is amber?
directly from the manual:
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100
Mbps or 10 Mbps Ethernet connections.
• Solid white. A powered-on device is connected to the Ethernet port.
• Blinking white. The port is sending or receiving traffic.
• Off. No device is connected to this Ethernet port.- bowlero2Jan 25, 2021Aspirant
I'm sure that the light is NOT amber, it is as red as as an apple. I have cable modem connected to the ethernet port, desktop computer connected to ethernet port #1 (both lights are blue/clear. Laptop is connected to ethernet port #2 and light is RED. We need to have the router connected to modem and desktop so that everyone else in the house can connect their devices and use the wireless network however this particular laptop needs an ethernet connection.
