bowlero2
Jan 25, 2021Aspirant
Nighthawk AC1750
Have owned for about a year. Most status lights are currently blue. recently purchased a cat 6 ethernet cable to attach to laptop and the status light is RED. Why the diffence between blue and red st...
- Jan 26, 2021
That router doesn't have any red led's built into the ethernet leds. . Its only amber/white.
check in your network settings to see if its connected at a 100mbps link rate. If so, its amber (but maybe looks red).
bowlero2
the laptop that is connected to the router does seem to work properly and without any problems, I'm puzzled by the red light when all other lights are blue/clear. Could if be possible that the ethernet cables are classifed as cat 6? The other two ethernet cables are cat 5.
Jan 26, 2021Guru - Experienced User
