Santoshroy87
Jan 07, 2022Guide
Nighthawk AC1750
Since the day I purchased my router (a year before), I have been getting speed around 150 mbps even though I had a plan of 400 mbps from my ISP. All these days I thought the issue was with my ISP. ...
Jan 08, 2022Guru - Experienced User
You have the R6700?
What modem/gateway is it connected to
How are you testing speeds? Wired? wireless
What device are you testing on?
If you have qos, traffic monitoring, parental controls, or access control enabled, disable them and reboot the router.
Those services require packet inspection and the R6700 doesn't have the cpu to do packet inspection above certain speeds.
Santoshroy87
Jan 09, 2022Guide
Hi there.. sorry to reach out to you again, just checking if you were able to see my response to your question. I am still facing the speed issue and if you can help me further, it will be really helpful to me.
Thank you once again.
