akatsushi
Mar 23, 2023Follower
Nighthawk ac1900 2.4 GHz wifi does not work but 5 GHz wifi does. Help please
So as title says my 2.4 GHz wifi is not showing in network list. The 2.4 lights on the router show it's working along with the control panel. I've tried a hard reset, changed wifi channel, and maki...
Mar 23, 2023Guru - Experienced User
What actual device do you have?
AC1900 is a speed not a model.
What firmware is on it?
Are you using smart connect?
