KevinSDiego
Apr 26, 2016Aspirant
Nighthawk AC1900 5GHz Channel stopped working
I got the router in December 2015 and has been working flawlessly. I've usually had 3 devices on the 5GHz network, and 3 on the 2.4GHz. A couple days ago the 5GHz stopped working. No devices can c...
- Apr 26, 2016
Please reset the device to factory default.
storm1985
Apr 26, 2016Prodigy
- KevinSDiegoApr 27, 2016Aspirant
That worked. Reading some more, older posts, that is an accepted solution and seems like it should be done after firmware updates. Just odd that things went south even though I hadn't made any changes in a couple months.
thanks,
