JIMJFRED62
Feb 11, 2017Tutor
Nighthawk AC1900 and Nighthawk AC3200: Do I need both?
For years I had a Comcast data modem and an old wireless router and last year I upgraded to the Nighthawk AC3200 wireless router. I just bought a new data modem--the Nighthawk AC1900. Do I still nee...
- Feb 11, 2017
Thanks for the advice. I converted it to an access point and it seems to be doing just fine...
Feb 11, 2017Guru - Experienced User
JIMJFRED62 wrote:
Do I still need the Nighthawk AC3200 as I noticed the new modem offers a powerful enough signal for all my equipment.
Perhaps not. Try turning it off for a while, and see if you run into any performance issues.
If you do want to keep using the AC3200, you could use it as an Access Point, and turn of the AC1900's wifi. There's a guide here: https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup?cid=wmt_netgear_organic
JIMJFRED62
Feb 11, 2017Tutor
