PD0OYH
Sep 02, 2015Aspirant
Nighthawk AC1900 Antenna type: Dualband?
Hello. I want to use high gain antennas on my R7000 AC1900. What type of antenna is the default antenna on all 3 connections? Is it single band or dual band? Manual and websites have no info about th...
- Sep 02, 2015
I am so sorry, i found my own answer at Ebay: http://www.ebay.com/itm/3-9dBi-2-4GHz-5GHz-Dual-Band-RP-SMA-WiFi-Antennas-Netgear-R7000-Nighthawk-AC1900-/301079053412
PD0OYH
VE6CGX
Sep 07, 2015Master
Hi-gain antenna means it is sacrificing omni-directional radiation pattern to increase gain to a certain
direction. And also it affects radiation angle(X & Y axis). As long as you understand this. As well antenna
impedance matching is very important. Mismatched antenna can result in loss of TX power or bad signal.
Trustworthy antenna will come with decent tech spec. sheet.
