Dunyduke16
Dec 30, 2020Aspirant
Nighthawk AC1900 Connection Issues
I purchased the Nighthawk AC1900 router last spring. I had been using the router provided by my cable company but was not satisfied with the coverage in my house. Since I've had this new router, I'...
Dunyduke16
Jan 04, 2021Aspirant
I wasn't able to find the manual, but my Nighthawk app tells me it's running version 1.3.1.64.
Thanks again for trying to help me with this.
michaelkenward
Jan 04, 2021Guru - Experienced User
I already provided a link for that:
Support | NETGEAR
Feed in your model number and get the manual.
That is not the latest.
- Dunyduke16Jan 04, 2021Aspirant
If it's not running the latest version, I'm assuming I should update it? Could you walk me through how that gets done? It doesn't appear that I have any updates available on the app.
- michaelkenwardJan 04, 2021Guru - Experienced User
Read the manual linked to above.
Or this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- Dunyduke16Jan 05, 2021Aspirant
Thanks for the suggestion. I followed the steps in the Nighthawk app, but it says there are no firmware updates available. Thoughts?
