DA-CA's avatar
DA-CA
Tutor
Oct 11, 2019
Nighthawk AC1900 cuts internet speed in half from wired modem
I am running the following Firmware Version
V1.0.9.88_10.2.88
I have read the message traffic that I need to go to a firmware version ov V1.0.7 or lower to fix the problem.  I do not see this version on the Netgear support page.  Where do I find this version or lower?
Are there any other fixes out there besides downgrading the firmware version?
  • Did you do a factory reset on the router after the downgrade to 42?
  • > Nighthawk AC1900 [...]
       "AC1900" is a speed, not a model number.  Look at the product label.
    > Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
       Not a router.
    > [...] cuts internet speed in half from wired modem [...]
       From what to what?  Actual numbers would be more interesting than "in
    half".
    > I have read the message traffic [...]
       Thanks for the helpful links.  _Which_ "the message traffic", where?
    > [...] I do not see this version on the Netgear support page. [...]
       _Which_ "the Netgear support page"?  Where did you look?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Downloads.  (For older versions, under Firmware and
    Software Downloads, look for "View Previous Versions".)  Find the
    kit(s).  Download the kit(s) you want.  Read the "Release Notes" file
    for instructions.
       Assuming that you have an R7000, you might first try 1.0.9.42, before
    going back so far as some 1.0.7.x version.
    > version?
       That might depend on what the cause of the problem is.  A Web or
    forum search for terms like "slow" might find any number of suggestions.
    • schumaku's avatar
      schumaku
      Wild guess - your router might be for example a R7000. Head to https://netgar.com/support type the exact product designation (as printed on the router product label), find [Download] ... below the firmware and utilities downloads you find a "+ View previous versions" ... here are the older versions listed. Be aware that older versions can (and do) have well known security issues - so mind your step.
    V1.0.9.88_10.2.88
    I don't know what you've been reading but that's not recommendation on these forums. The recommended version depends on your router model (not your router speed) which you haven't provided. I'm guessing your model is a R7000 based on your firmware version number. If that is the case then the recommended firmware version is 1.0.9.42 which is availble on the download page.
    There are lots of solutions for many different problems. You haven't provided enough information about your problem to narrow it down.
    • DA-CA's avatar
      DA-CA
      Tutor
      Here is the requested details of what I am running and the issue I am having.
      R7000 — Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
      Hardware Version            R7000
      Firmware Version            V1.0.9.88_10.2.88
      Download speed:
       - Modem direct to computer via ethernet cable = 226.6 Mbps
       - Modem direct to router and then router direct to computer via ethernet cables = 113.27Mbps
      Upload speed: 11Mbps with either method
      Modem is Motorola Surfboard SBG6580
      I have powered cycle both computer, router, and modem allowing a minimum of 5 minutes of complete power off.
      Searched on the following web page with the following parameters "download speeds cut in half", without finding an appropriate solution
      https://www.netgear.com/support/product/r7000.aspx#page-2
      • yddtime's avatar
        yddtime
        Luminary
        As previously suggested above downgrading your firmware to 1.0.9.42 is your best bet. There are just too many issues with 1.0.9.88
