DA-CA
Oct 11, 2019Tutor
Nighthawk AC1900 cuts internet speed in half from wired modem
I am running the following Firmware Version V1.0.9.88_10.2.88 I have read the message traffic that I need to go to a firmware version ov V1.0.7 or lower to fix the problem. I do not see this ve...
- Oct 17, 2019Did you do a factory reset on the router after the downgrade to 42?
yddtime
Oct 16, 2019Luminary
As previously suggested above downgrading your firmware to 1.0.9.42 is your best bet. There are just too many issues with 1.0.9.88
DA-CA
Oct 17, 2019Tutor
I downloaded and installed the following and rebooted the router. Verified the firmware installed correctly.
Download speed is still the same 110 Mbps (half what it should be)
Firmware Version V1.0.9.42_10.2.44
