benttree1615
Mar 09, 2018Follower
Nighthawk ac1900 disable airtime fitness
Trying to connect my Sonos Sound Bar to my network. I am told that I need to disable "Airtime Fitness" on my router. Any suggestions?
- Mar 10, 2018
antinodewrote:What does this noise on every posting add to the discussion?
This is obviously content coming from the users signature and not part of every post. Blame the (very substandard) re-design of the community forum for not making this graphically obvious enough. Many more details on the community redesign are poor - everything is massively oversized. Font sizes in posts are not the same for normal paragraph vs. numbered or bullet lists, and much more. Can't be users working on notebooks and desktops have to massively scale down the community page to have normal font sizes for example, too. Either the designers use tablets and mobile phones only, or are hobbyists, or both. User side (browser) spell checkers are forced disabled in the rich text editor. Embedded image pop-ups are smaller (narrower) than what is already visible in the browser, resizing is not possible. Related comments with Netgear are unheard or blamed to the SaaS platform. Complain whee complaints belong - and not with people spending a lot of time, effort, and know-how here - for a few Kudos.
We're off topic here, sorry to the original poster.
Mar 09, 2018Guru - Experienced User
Try looking under Advanced/Advanced Settings/Wireless and see if this feature is there.
benttree1615wrote:Trying to connect my Sonos Sound Bar to my network.
Any suggestions?
- antinodeMar 09, 2018Guru
> [...] I am told that I need to disable "Airtime Fitness" on my router.
Who, exactly, tells you what, exactly? "Airtime fairness"?
FURRYe38:
Why do you always quote entire postings when replying to them?
> Motorola MB7420(200Mb/10Mb)>Orbi AC2200>HP 24pt Gb Switch.
> R7800(Voxels v.4xSF FW), and WNHDE111
I don't know which is more annoying. Which do you think is?- schumakuMar 10, 2018Guru - Experienced User
- FURRYe38Mar 10, 2018Guru - Experienced User
Been complaining about the format and how NG forum is displayed. I can't agree more with what you said. I do have scale down and zoom out. There way too much scrolling to get to the content and actual posts. Why is the SEARCH window so large?
Ok, sorry for being off topic. Wanted to fill in.
Theres nothing against Quoting people. One reason is so I don't have scroll down so far and keeps the information flow. I'm here to help people solve problems as best as I can. Not applogizing if you don't care for my methods. I'm not here for you.
Thank you.
Now back to our normal programming. Appologies to the OP. Glad the poster found the answer.
