dosohkaknife
Feb 08, 2023Aspirant
Nighthawk AC1900 does not print windows 11
Epson L210 is connected to the router via USB, native utility Netgear USB Control Center 1.36 is installed on all computers. On the 1st PC Win 10(32) Pro everything works properly, on the 2nd Win 11...
Feb 08, 2023Guru - Experienced User
Something to contact the printers Mfr about for support and information regarding there product.
Something to ask them about drivers for Windows 11 vs 10.
Good Luck.
dosohkaknife
Driver is working. If the printer is connected directly to the computer via a usb cable, then everything works.
- dosohkaknifeFeb 14, 2023Aspirant
Who is running ReadySharePrinter_v1.36 with windows 11 (64) and prints?
- KitsapFeb 14, 2023Master
Check the settings on your Windows 11 computer. Under Network & Internet -> Status, confirm your network properties show the profile as Private and not Public.
Network & Internet -> Status-- Private
