Capela24
Oct 23, 2021Follower
Nighthawk AC1900 doesn’t work with Spectrum modem
I was using the AC1900 C7000v2 wifi modem/router for my spectrum internet service. Then Spectrum sent me a new modem I have to use to avoid service shut off. So I setup the new Spectrum modem and try ...
Oct 23, 2021Guru - Experienced User
the problem is that the C7000 is a modem/router combo device.
It can be used as strictly a modem or as a combo device. But not as just a router.
There is a way to use it as an access point but you'd still need a router to connect to the modem.
This is the first that I've heard the spectrum is forcing you to use one of their modems.
